My dad for years hauled his 1959 D6 B model on a tilt bed trailer pulled by a 1961 corn binder with a big gas V8. He was a master at feathering that cat just enough to gently set the tilt bed down.
https://www.bigmacktrucks.com/topic/63509-old-cat-being-loaded/#findComment-457094
Yeah, you always looked for the balance point, and then eased the blade down.  That would generally shift enough weight to cause her to ease down over the break-over point.  If you didn't, she was likely to come down hard, and then bad things could happen!  Definitely took a light touch.  Made you feel good when you did it right, though.
https://www.bigmacktrucks.com/topic/63509-old-cat-being-loaded/#findComment-457130
