  • 3 months later...
This is a multi buzzer, it buzzes for air, oil pressure, coolant level, and ....yes the dang turn signal... its annoying, there is a triangular bracket left of the clutch pedal, there is a wide plug that goes to it, you can unplug it...however you need to watch gauges, because now its like an old timey truck where you have to watch the gauges, because there wont be a warning buzzer, also.. if the D.O.T. man pulls you over... plug it back in...JOJO
