1 hour ago, JoeH said:
I'm clueless, but someone once told me peterbilt triaxles are typically set up that when you set the parking brake the lift axle comes up?  No idea if that's true/common setup or not.  No Mack I ever drove did that.
Yes we have one set up like that where I work. .  2005.    the 1998 isn’t set up that way
https://www.bigmacktrucks.com/topic/63828-pusher-axle/#findComment-459229
