Ok changed unloader valves no change at all. Still popping off every 10 seconds. The air compressor was replaced about 3 years ago. I guess it’s time to change again? Does anyone have any other idea what might be causing this type of problem?
thanks!!
https://www.bigmacktrucks.com/topic/64434-water-in-air-tanks/#findComment-462650
I went through the same thing your going Thru one time. Did everything you did and the last thing I did cured it.  Changed the air dryer and all was good.  Pulled the old dryer apart and it must have froze at one time it had a crack where the filter cartridge went on it I found it by putting a torch over the whole body and in about 1 minute you could see the crack.  Other than that don’t know what to tell you
https://www.bigmacktrucks.com/topic/64434-water-in-air-tanks/#findComment-462664
