I'm not at all familiar with that engine but sounds like that rocker isn't getting oil. If it is oiled through the push rod the rod could be plugged. Whatever pool gallery feeds it must be blocked. I'm assuming that the valve lash is set correctly.
https://www.bigmacktrucks.com/topic/64482-ticking-sound/#findComment-461993
  On 10/6/2020 at 3:00 PM, Vicki said:
Was told the push rod was changed. Still ticking. They are pulling the head to see if it's a valve.
Expand
Probably not a bad idea. I had a 3406 CAT in an '87 LTL 9000 that had a tick. Found a bent push rod, replaced the rod, set the lash and the tick persisted. I was taking the truck to a mechanic friends place (12 miles away) to have him check it out and on the way it dropped the exhaust valve in the same cylinder that the push rod was bent and put the rod through the block. The tick went away 😜
Edited by Licensed to kill
https://www.bigmacktrucks.com/topic/64482-ticking-sound/#findComment-461999
  On 10/6/2020 at 10:18 PM, Mackpro said:
If ETECH. Could be “H ring” in block that holds and alings the roller lifter . It can be dislodged and can cause roller lifter to cam alignment issues
Expand
Had heads checked and they are good. Mechanic said he ordered a special tool to check the H ring and it's in the right place.
https://www.bigmacktrucks.com/topic/64482-ticking-sound/#findComment-462111
  • 4 weeks later...
Don't you ever consider of getting a Brisbane truck mechanics that are mobile and can go to your location for repairs? It is very effective when needed.
We provide Mobile Truck Repair Services and more. Visit our Home Page/Website for more information.
https://www.bigmacktrucks.com/topic/64482-ticking-sound/#findComment-463354
