You're most likely going to have to make one yourself or pay someone to do it for you. What are you calling the wiring harness? There are a lot of simpler sub-assemblies to various parts of the truck, and then there's the interior wiring. There's not a likely source for an exact wiring harness for your truck.
Dan Bruno
www.stlouisdumptrucks.com
https://www.bigmacktrucks.com/topic/645-wiring/#findComment-3077
Dan Bruno
thanks dan, theres really just alot of wire (cleanup)throughout the truck:old splices ,corroded ect. i thought maybe a complete harnness would be easier guess ill be wireing for a while :) anyways thanks for your responce.
p.s www.stlouisdumptrucks.com is an awsome site with tons of info
thank you
sean :thumb:
https://www.bigmacktrucks.com/topic/645-wiring/#findComment-3084
  • 2 months later...
I used to work for Sutphen Corp. in Hilliard, ohio as a fire apparatus electrician, and we used heat embossed MTW wire, it costs a few dollars more, but the writing doesnt wear off(its melted into the wire jacket), it comes in a rainbow of colors, they will do anykind of custom orders, and it is lettered everyfoot, ie- 27 Left Turn, 26 Right Turn.........
The supplier we used was a company in Bellfontaine, Ohio called EWS Spectrum.. you can look up their number...... they will work with anyone and are very knowlageable
Just some food for thought, hope this helps
Erik
Erik
https://www.bigmacktrucks.com/topic/645-wiring/#findComment-5205
