Just got finished serving my 2016 MP8 505.  Go to crank it and the shut down light and electronic malfunction light are on.  My scan tool shows code U010C which is lost communication with the turbo.  What caused this?  Where should I start looking.   All the wires and harnesses look intact around the turbo.
https://www.bigmacktrucks.com/topic/65089-mp8-lost-communication-with-turbo/
There is a fuse for the turbo , I can’t remember which fuse box it’s in though.  Also, other sensors on the same 1939 data that the turbo is on could be shorting out causing the issue.  On some year models the DEF level sensor is on the same data link as the turbo. Make sure your DEF level guage is working
