  • 0
Question
2015 mp8 when under heavy load. antifreeze pushes out the overflow tube. Checked EGR at Mack Barrie Ontario and it looked fine.
also when you look at the plastic rad tank when the engine is hot. it look to be down 4 litre but when you undo rad cap a little  and let air out the
level goes up and it may only be down 1 litre  and if don't ad 1 litre it will shut down power Not cool on a 10% grade with no shoulders
https://www.bigmacktrucks.com/topic/65166-owner-operator/
2 answers to this question
Answer this question...
