Hello, Does anyone know the part number for the head studs, My studs bores are 5/8X11 thread, The tops are fine thread..? I was about to install my heads and when I opened the boxes of studs that i have. They were smaller, Probably 9/16".... I guess there for an END 18 hole engine.. I have a 20 hole engine.. Thanks, Jojo
https://www.bigmacktrucks.com/topic/65285-e-6-2-valve-head-studs/
Back when I had to replace a couple studs on my 673, I was going to check with ARP and see if they had something comparable.  I never did check as I came up with a couple oem studs.
I was working for mack when the 20 stud block was changed from studs to cap screws. The best i can remember was same block was used on the first maxidyne which used cap screws plus the different liner that used the fire ring head gasket and a groove in the head.So check the cap screws out for a replacement for studs.The first ENDT 673C used studs
Yes sir, I know what your saying, My customer wants it original, I may be able to convince him to use bolts... Talked to him today, w'ell see... I think e-7's had sae threads... 5/8x11.....    Thanks for youre input, Jojo
thanks,,  I had a brain fart, I dont do as many anymore. I built an e-7 3 months ago, but off course forgot ... Thanks again... I'm getting rusty:)
