Hi I have a 70  r608 707 gas job never built much water in the tanks started running a little bit 3- 400 miles over a month starting get a lot of oil in the air tank is there a valve  or something in the compressor head could be passing oil through could use some good advice thank you
https://www.bigmacktrucks.com/topic/65291-oil-in-air-tanks/
Engine Oli is getting past the Cylinder rings on the Compressor piston..
Time to either rebuild the Compressor or get a New/Exchange one..
Because those that matter...
don't mind...
And those that mind....
don't matter." -
https://www.bigmacktrucks.com/topic/65291-oil-in-air-tanks/#findComment-465629
keep draing all the airtanks more often
let all the tanks drain ovrnight
fit taps to drain tanks
also aircleaner may need a clean
when the compressor cuts out @ 120psi
the compressor pistons Rfree wheelin & can suk the oil up past the piston rings n then it gets blown down into the tanks
the above can happen if the engine & compressor use the same aircleaner
BIDS2BC
cya
https://www.bigmacktrucks.com/topic/65291-oil-in-air-tanks/#findComment-465631
When I first went to drain the air tanks on my 1975 R685 I found that the passenger side tank had a quick disconnect in the tank where the drain should have been.
what a mess came out of the tanks on that truck. There was even oil behind the dash and above the headliner due to an air leak at the air horn valve.
I would check the air filter and drain the tanks daily to see if this is a real problem or something you can live with
does the truck have an air dryer on it?
https://www.bigmacktrucks.com/topic/65291-oil-in-air-tanks/#findComment-465672
Yup, the back of my dash was grimy with oil/dirt from the my air wiper switch.
https://www.bigmacktrucks.com/topic/65291-oil-in-air-tanks/#findComment-465707
  • 1 month later...
  • 5 months later...
  • 1 month later...
