Milkmans suggestion top of the heep! Heres other stuff to try Lock out the interaxle diff See if it changes! = Tires size!  Equal ?! Rest your foot  Foot on the clutch pedal Listen to see if the noise is still there looking for worn linkage! check the trans tail shaft for tightness ! Ujoints loose ? Rims Are they Steel Buds? = check for cracked rims! Lots of places to look! Last but not least chec the diff plugs see if there is metal in the oil  If there is lost of metal on an plug magnet you may have a failing diff! Not uncommon to have crown gear bolts break!
Just sayin!
https://www.bigmacktrucks.com/topic/65563-owner-operator/#findComment-467303
