Anybody have part numbers for the replacement bearings and seal for the water pump. I think I have a bad pump so I want to rebuild it and rule it out.
I'm getting air entrained in the antifreeze that is not overflowing the filler neck at 2000rpm. No water in the pan or oil in the water. Antifreeze stays green when settled.
Thanks everyone!
https://www.bigmacktrucks.com/topic/65635-end673-water-pump-seal-and-bearing/
sorry cant help you but i would talk to autozone,,,and have them send it out..unless of coarse you have a local established auto parts...here in reno thier all gone. no one has any choices but chain stores,or dealership...good luck...bob
I've used these guys over a dozen times through the years with great service and turnaround times:  http://www.waterpumpkit.com/
Cost is usually just over a hundred but I've never had a problem with their work. I had sent one in for my 64 B-61 and the casting was bad. They had one charging me $10.00 for it.
I'm sending the water pump from my 57 Hobart Bros. welder to them later this week as it's taken to leaking from the weep hole.
If you could let me know your available part numbers for the B series as I've got a couple of later model install projects coming forward.
Thanks,
On 1/25/2021 at 6:07 AM, Frank Y said:
Same here. 3 chain auto places literally within 100 yards of each other.
We had a really huge one here independent he mad a really big machine shop as well all of a sudden they were gone... bob
