- 0
Mack t2080 transmission?? Mack Beam suspension??? Mack Fan ?? Frame???
Question
Sehka77
Hello have a question regarding Mack t2080 ? I understand its a 8 speed 123 low and 12345 high? How should you shift this transmission? Use all 8 speeds? Also I am able to use/ shift 12345 low and 12345 high. Is doing this bad to the transmission?? I confirmed its t2080 from dealer so not sure why I use 4&5 in low as well ? Is Mack beam suspension 80k capacity? Or what's the capacity? Also have Mack Fan in truck has heater/ aC but to ac compressor anywhere is this really an a/c unit or how does it work ? Also truck has single frame looks to be about 3/8 inch is this heavy duty whats the capacity? Thanks everyone
Edited by Sehka77Link to comment
https://www.bigmacktrucks.com/topic/65721-mack-t2080-transmission-mack-beam-suspension-mack-fan-frame/Share on other sites
10 answers to this question
