Im new with macks and I will like to know how the differential  lock is activitaded in Mack 2016 613chu, when i press the switch i hear the air activated by tandem then press again and hear a click noise, not sure when is activated, dont want to damage the differential, thank you, and if i turn off the switch will go back to normal. Thank you
https://www.bigmacktrucks.com/topic/66203-differential-lock/
there is a bank of celenoids on the frame rail or a cross member rear of the cab. each one has a job.  that is where you can find if air is being sent to the powerdivider,  and fifth wheel nd suspension, and air ride,,, anyway, you get it... your truck is a Volvo.... jojo
https://www.bigmacktrucks.com/topic/66203-differential-lock/#findComment-470389
