Hello,
I replaced oil Pan gasket on my E7 427 engine because it was leaking one of the bolt hole is cross threaded. I didn’t realize this until the oil Pan was back up and I was trying to put that bolt back in so I pull the bolt looked at it the bolt threads was ok so I shined my light into the hole and saw the threads was messed up. Do you all think I could just leave that bolt out without the Pan leaking?
https://www.bigmacktrucks.com/topic/66321-will-oil-pan-leak/
Thank you all for your help... in the spot where the hole is located which is up in the front of the Pan I couldn’t actually use my hand I did use the socket and extension to get it started then I attached the ratchet after.... I also thought about trying to use a tap to correct the hole but it’s just the location so I was hoping I would be okay without a bolt being there.
https://www.bigmacktrucks.com/topic/66321-will-oil-pan-leak/#findComment-471195
