Larry after reading about your truck I slid in a rear out of a freightliner air ride I wish my truck was a little longer wheel base I think it would help. Is your tranny a 15 or 13 I ended up with a double over triplex and a 3.90 rear I could of lived with the 4.64 rear I had.
https://www.bigmacktrucks.com/topic/66400-a-ride-in-my-b/#findComment-472400
Dave, it's a 15 spd(single over).  Many years ago I was looking for a double over to get more road speed out of my 4.62's.  Never happened, so I cut the gearing when I added the air ride.  The rear actually came with 3.70's but figured I'd never use OD with the old 673 so I swapped it to 4.10's.  Now I wish I had kept the 3.70's.  The 237 would likely do real nice with that ratio?  Right now it is 65 mph at 1800 rpm in OD.  I think I could knock a few RPM out of it without hurting anything.
Mike, sorry no radio or tape deck.
Keith, I made sure it was plenty low enough...LOL!
Edited by Freightrain
https://www.bigmacktrucks.com/topic/66400-a-ride-in-my-b/#findComment-472449
12 hours ago, Freightrain said:
Yes, moved the nut.  It would only get maybe 900* on a hard pull. Now it goes about 1100*.  Fuel economy has not changed.
Well I hope the boss doesn't see the broken seal on the pump, you'll have to fire yourself for tampering with the pump.
  • Haha 1
https://www.bigmacktrucks.com/topic/66400-a-ride-in-my-b/#findComment-472511
