Ok guys dump truck 425/65/22.5 steer tires
Truck has a bad bounce from 30 til bout 50 then it kinda settled down
But it is not comfortable driving bouncing inside
Had a alignment down it was out plan to put on new steers next week
Was going to Tru and balance tires thats on it but I'm just going to replace
Any thing I should be looking for
King pins are good
It's a stiff bounce like from side to side not back to front
Thanks for any help
https://www.bigmacktrucks.com/topic/66536-2000-rd688-front-end-bounce/
If alignment and tires don't cure, might be a bad wheel that is out of round or you might need new spring packs.  I've never really noticed any difference with new shocks compared to worn shocks. Also check the motor mounts, they normally make more of a banging sound when they are worn, but if they are shot possibility that it could perpetuate the bouncing. That was a lot of words to say in my experience a speed related bounce has almost always been tire and wheel related.
on rare occasion seen  drums out of balance !
I've seen worn tie rod ends cause a side-to-side shake.  But, you would hope the alignment guy would have checked that.
Most common though is wheel or tire...especially if it "didn't use to do it".
A bad brake drum can cause a weird vibration as well. Some of the cheaper aftermarket drums aren't well balanced.
A clump of dirt stuck between the brake drum and the wheel can cause a speed related wobble. Only dealt with this on budd or hub pilot wheels.
If you've got spokes on the front then jack up the front axle and spin each wheel by hand to check the alignment. Not everybody is well versed in the old stuff and it could be wobbly.
Took front wheels off looked at drums
They have holes that are way bigger then the stud
Centered them best I could put wheels back on bounce is not completely gone but it better
I think I'm going to get so.e new drums new tires balanced and hopefully it's gone completely
Thanks guys for your help
425 is a bigass tire... rekon you have a broken belt in the tire?   is this an RD?  whats the bolt pattern? budd, spoke, piloted?
Edited by Joey Mack
More content needed
