Hello all I have a 1962 b42 that I am installing an air ride cut off to the rear with hub pilot wheels .I want to swap out the entire front axle to hub pilot too I'm thinking it will be easier to find and axle and modify it to fit rather than finding hubs  has anyone done this or know of something that would fit or does anyone have a stud pilot axle that would work? any brand is ok I would just like aluminum wheels all the way around any help is appreciated thanks
If your going to be a bear be a grizzly
https://www.bigmacktrucks.com/topic/66558-1962-mack-b-42-front-axle-swap/
  • 4 months later...
I’ll try and find you pictures.     I swapped mine out from a fld freightliner.      If you can search my old posts some how i believe in the antique section I posted pictures and what parts I did.      Only thing I’m not sure about is what hubs I used.     They came off a different axle then what I used but helped tuck the tires in the fenders a little more.
