Went through heads. Valves gaskets everything. Re assembled..... Truck refuses to fire.  Been constantly cracking and bleeding injector lines. Fuel pumping there.  Injectors were all the done. New nozzles and pressure set.  She acts like she wants to go but isn't quite there.  Any suggestions?
https://www.bigmacktrucks.com/topic/66647-237-head-gasket-replacement-wont-fire/
I would temporary install electric fuel pump into the fuel supply line or even attach a hose with such a pump and sunk into a jerrycan. Straight jumpering electric terminals takes all air and so from the primary circuit in less than half a minute. Than I would crank with the pump still on. If it's a matter of fuel supply or air the engine would start quite soon. If not your way is to investigate assembly mistakes. Such as injection timing, cam shaft timing, valves adjustment etc.
