My friend has an eaton in his E-9 Superliner. its a 15 spd. heres the vin... RW713/001554
Edited by Joey Mack
More content needed
32 minutes ago, Rvalentine9 said:
Thanks
don't think the the 15 speed bell housing is the the same ! may not fit the 18 speed you need an eighteen sp with the mack bell housing you will also have to alter the clutch lever and mount bracket! We have a customer with the the setup you need I will check his vin next week !
