  • 0
tip turbine check valve
Question
2 answers to this question
  • 0
Dunno if they are or arent available
What makes you think its worn out ?
I had my turbine apart recently and there really didnt appear to be anything to bugger up on the valve
It is spring loaded and I had just cleaned around it etc as best I could
Even if they arent available I think just a normal check valve from a plumbers would work in the short bit of hose
 Paul
Answer this question...
