I have a 2013 CHU613 and I keep losing my voltage at my compressor making the ac stop working. If I turn off the truck and turn it back on the ac will start working again briefly. I’ve ohmed out the compressor, changed out both pressure switches, swapped expansion valves, ac is fully charged, swapped out relays, changed out the ac diagnosis module and checked all the flappers in the cab. Any other ideas of things I could check would be greatly appreciated. Thanks
https://www.bigmacktrucks.com/topic/66773-ac-compressor-losing-power/
Is the evap core freezing up and shutting the system down? Do you see a good flow of water draining from the drain tray on to the ground when the A/C/ is on?
I had another thought. did you put gauges on it and see the high side pressure?  if it spikes passed the High pressure setting, it will shut the compressor off too..
