  • 4 weeks later...
I have just completed (and test run) a converted AC engine. Relatively straightforward as long as you have access to a decent lathe. We decided to machine the flywheel in such a way that the ring gear sat in a rebate so that the outer was the same diameter as the flywheel. We then 3d modelled and 3d printed a starter mount before casting it and machining it. We machined it deliberately to require shimming to ensure the correct meshing of the starter pinion.  Because we are in UK I decided to start with a suitably sized ring gear (which, incidentally bolted on rather than being shrunk on (although we did machine the flywheel for a press fit) then sourced the starter motor to suit.  In my case I went for a truck set up and 24v, so if required I can jump start it from a (modern) truck.
Video here:(11) Facebook
https://www.bigmacktrucks.com/topic/66910-1927-mack-ab/#findComment-476062
