Look into changing over to Pertronix electronic ignition. It is not terribly expensive and you will not regret it.
As for the fuel pumps, good luck, any used ones you find will be in just a poor condition as the ones you have, recommend rebuilding the ones you have if you can find new diaphragms. And after you get it running try to only use non-ethanol gasoline to avoid trashing the new diaphragms and other rubber parts and to prevent clogging the carb.
No mechanical pumps or parts? Install an Airtex electric pump.
https://www.bigmacktrucks.com/topic/67137-r608f-ignition-coils/#findComment-476004
