do you have 2 buttons on the front of the gauge panel? if so... are the rubber boots missing allowing dust to get in the buttons?  I assume that this is a road truck and not a dump truck since its a CXN...  but anyway, try to clean the gauge panel with dry compressed air, I suggest removing the cluster to do this... its easy to do.. jojo
https://www.bigmacktrucks.com/topic/67498-alittle-help/#findComment-477374
Yea it’s a on road truck it has two buttons on the cluster to push the rubber part of the buttons are in tact. I have xc613 similar to it as well and I can’t get that one to work either so I thought maybe I’m doing something wrong. Iv had the face cluster off but didn’t use any compressed air.
https://www.bigmacktrucks.com/topic/67498-alittle-help/#findComment-477377
