  • 0
Battery and key toggle switches
Question
4 answers to this question
  • 0
Trying to hook up extra lights. Just trying to find the wire lead for the battery and key toggle switches. I know the cv713 was right side of dash where the fuses were. With the new trucks I can’t find the wire lead to use the toggle switches
  • 0
What year are the new trucks?  the CV doesnt have an acc relay like previous trucks, it has a relay block plugged in ,,,  to the left of the fuse panel...  If you just want to run power for light s etc...  depending on what the demand is,,, there are plugs in the dash harness that are not used and you can use one of them, and add a fuse to the circuit..  you can also I.D. the wires in the dash by reading the numbers on them. The fuse number is printed on the wire.  check it with a DVOM to ensure you have the correct wire related to the fuse socket in the panel. there is probably 10+ ways to do this.. You can also connect to the relay on the fire wall to get power, or the EPDM on the fire wall left of the steering shaft...  Someone else will chime in with more exact info...  jojo
Answer this question...
