Hate to be the guy to tell you, but this model and year were not very reliable. Mack came out with updates on their entire egr system and turbo. They had updates for the updates.  Check with your Mack dealer and see what has been done. They should see the repairs because most of these updates were completed while the vehicle was under warranty.
As for preventing any future failures, other than regular maintenance, there is not much you can do.
V
https://www.bigmacktrucks.com/topic/67555-turbo-question/#findComment-477752
the turbos and egr valves on the ASET-C ( assuming your's is CEGR) engines arent that good. and very expensive to fix, if you can even get a turbo due to the current parts issues. I have been getting turbos re-built. I just had one done for an E-9 that I was tunning.  is the engine throwing codes? jojo
https://www.bigmacktrucks.com/topic/67555-turbo-question/#findComment-477753
