2 hours ago, Hayseed said:
Vlad is correct Brocky..Mack Australia used the R Model chassis for everything..
Vlad, I own one of those COE Magnums. They came into the country as Glider Kits. Cab, Chassis & Front Axle.& were fitted with the entire Drivetrain Here. It has the euro 335pcd Wheels all round..
The Quantums were a little bit Different. The early Ones came in as Glider Kits, & were quite problematic. the Later ones were CH Chassis fitted with the Quantum Cab, & where a far better Truck by All accounts..
Pretty sure there's a Thread (or 2-3) here about them..
Seed, pretty imteresting to hear. I would like to bother you later a little bit, will send you PM. I like those big Renaults with air suspended cab and flat floor and tried to learn the design of their Australian version for a long while.
So I had another run at the old girl today. Compressor is building air just fine. Took the high low selector valve ( left hand side of the gear box) apart and replaced the o rings. It had a bit of surface rust inside it but I couldn't see any real damage. Still chasing up other problems as this didn't fix anything! Oh the joys of mechanical work 🙄
