The fuel lines could be different themself where attach to delivery valves. They look so but I haven't checked. So could be interchengable either. The firing order is definitely the same since it's predicted by the engine operation. Another thing I'm not sure about is the firing point. Different pumps may have different initial angle since they have different design. But may have it similar. Worth to check out the data for the similar engine but equipped with the other style of the pump.
I'm hoping I don't have to bend the lines to hook up, if I do I will probably use the injector lines for a Ambac pump. is the Ambac pump better than the Robert Bosch, the Amac pump looks like it's a better built pump and a little heavier. Thanks for your help guys
