I finally bit the bullet and bought 4 new 11:00R x 24 Sumitomo's for my B model.  On my way home I could see in my mirror the right side had a fare amount of "wobble" and my son who was following me confirmed.  Took it back to dealer and his HD truck guy spends a lot of time on it and it is not much better.  I jack it up and say it is at least 3/4" off.
Now tire guy says.."you know you have to put at least 100 miles on them before they "seat in".  Anyone have an opinion on this.  Mechanic also says I have wrong spacer on it but I say..had no problem with old caps??? Same spacer!  So  what's changed?
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/
36 minutes ago, Red Horse said:
Hah!  Claims he is a class A driver and this is a temp job but you might be right
Get the guy with grey hair he can fix it wright...........and if he has a CDL and changing tire's....?
Ed
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479733
Get it in writing that after 100 miles or so and its still not wore in, you get a new (wobbly tire). How come the other three tires are running true? That's what the gray hair guy is thinking but maybe not saying!
Edited by james j neiweem
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479742
Where did he graduate (top of his class) from New England Tractor Trailer School?
Bob had he ever seen a Dayton wheel before?    .....Hippy
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479745
I’m sure he didn’t true it up I used to do hundreds of them,,,  but these days I’m sure most tire shops don’t know how to do them… I see containers all the time with duels wobbling  I would gladly hook you up but I’m afraid you’re too far away… bob
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479748
I suppose anything is possible ….. these days it’s hard enough to get kids to do anything,,,,,, never mind skilled labor And yes I consider anyone working with split rims and  spoke wheels  skilled …  like somebody said anyone with gray hair could probably do it ha ha… bob
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479779
Yes Hippy I'm sure  he has.  This shop advertises .."light commercial" but everytime I'm in there (I've bought 12 tires from him in last two months) I always see a 24", 22.5 or a 24.5 leaning against the building and plenty of skid steer/ back hoe rubber.
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479781
10-4 Bob on the gray hair!
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479782
Yep I do... The Tyre Fitter has NFI what He's doing..:idunno:
Go to the 11.00 mark here & Watch..
Because those that matter...
don't mind...
And those that mind....
don't matter." -
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479785
Hayseed posted a video that pretty much shows you how to get a Dayton to turn as true as disc type wheels.  If that was followed , the only way it won't run "true"  is if the spider is missing the flange where the inside rim rides on.  (they sometimes get damaged from a wheel spun that wasn't tight for some reason)  That part he's doing with the hammer (checking run out)  some guys refer to as indicating .  I think you were just unlucky enough to get a lousy guy putting your tires on.  I'd suspect going back there, you'll just get blown off with anyone's advise from here (lol)
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479788
It shouldn't really matter if the inside of the spider is worn or spacer is a tad bit out of shape the outside wheel should be able to run true pretty easily
I haven't had many dramas over the years, if any trying to get them run true
Some times I gotta back the nuts off to pull it up a bit on one side, but all in all I  never felt it was to difficult
Paul
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479789
Too True Paul, I've done It at 2.00am with a Torch in my Mouth (Pre head torch days) & got them to within a couple of Bee's Dicks..
don't mind...
don't matter." -
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479791
another skill that has been forgotten. budd wheels easy. daytons take time to be done right. no way can a dayton be done with air gun only. 3/4drive ratchet  and block of wood (or spray can works-it's high enough). criss-cross by hand the tightening sequence . have seen tire casing that were out of round also. on a good day have been able to get the daytons 1/8th  true. using a tall spray can, the spinning tire will show how far out of true the wheel is. good hand tight then finally tightening with air gun.
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479795
Thx guys for the comments.   Never heard the "no impact gun" rule as stated in Swishy's post. this guy was  using a 1" gun!  And I've always been of the belief when you tighten a "high" clamp you then spin as close as you can to the opposite clamp.  This guy would tighten a "high" clamp and then proceed to go around to the next spoke.  My fault-I'm saying "his job" and he is correcting his mistake not on my dime.  I should have jumped in and said..."what about  trying this".....
Hayseed...."couple of Bee's Dicks"??  More like .".Elephant Dick"🤣
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479796
This has been an interesting thread. I have VERY little experience with daytons, the only ones i have had were 17.5" with he three spokes that branched to two nuts each with a bridge. I HATED them. Never had any problem getting them to run true but had nothing but problems getting the bridge to come off. However, I always put them on with an impact and used the impact to true them up so that may have contributed to the bridges getting so wedged on there that it was a real bear to get them off.
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479798
Webb wheel's very good hub's
Ed
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479799
blackdog2
62 ton concrete  I-beam; did you work for blakeslee prestress ? mid 70's blakeslee rented a fleet of DM 611's from new haven truck rental. huge single axles and tandems . had 4in spacers under the 100 ton  turn table fifth wheels.
https://www.bigmacktrucks.com/topic/68077-1100r-24-tire-wobble/#findComment-479800
