When I'm at a stop light and take off when the truck reaches 7th gear sometimes it will not accelerate so I would let off the gas pedal then give it gas then I would hear a thunk noise and it will take off does anyone know what the problem could be? It only happens towards the end of the day.
https://www.bigmacktrucks.com/topic/68160-transmission/
the wire harness is a small one, and it runs over the left frame rail under the cab. I have replaced these due to them chaffing where it goes over the frame edge.   its costs under $150.00 3 years ago when I did the last one...   jojo
https://www.bigmacktrucks.com/topic/68160-transmission/#findComment-480418
On 9/16/2021 at 6:46 PM, kt_Engineer said:
What transmission do you have? If it is 12-speed MDrive, something seems to be confusing TECU where it is trying to go to low range (from high range) or could not go to Hi-Split in main box. Maybe splitter synchronizer is going bad.
I agree it sounds like the synchronizer this a weak point on the Auto a fairly common  Failure specially I its left with the second speed programing in reverse ! This is a theory  however ! But it Seems to knock the sycro cone loose from the hub due to its design it seems to happen more frequently on those with the two speed reverse program left enabled!
https://www.bigmacktrucks.com/topic/68160-transmission/#findComment-480559
  • 4 weeks later...
