to many reasons for the issue.....  whats been done to the truck?  fuses? relay's? . is it a dump truck?   catch my drift?    jojo
Not much no extra lights or anything daycab tractor just don't have any juice to the marker light side with a test light. Has the old style ground through light combination lights under the door.
I didn't know if there might be a common issue with it or where to start getting tires put on tomorrow and need to get an annual done I it to put it to work . If need be I'll just run a jumper wire to them just thought it was weird they both work on the turn signal side
the turn signal bulbs have 2 filiments in them....  2 different circuits....   the markers are on thier own....
Yeah the ones under the doors, should light up solid as a markerbut don't unless I'm wrong . They have a dual element bulb, two wires into plug and ground through light Everything else works fine
Well if that don't make me feel like a dummy, I could've sworn they should have functioned as marker lights also since they had a dual element bulb. Isn't a side marker required? And why two wires to the plug when the light grounds itself.
Well thanks for the help I was sweating that! I need to get an annual done on it after I get tires and thats the only issue I can find, had me pulling my hair out. Thanks again guys I really appreciate all the help.
