R and DM/U cabs couldn't be the same since the latter were offset to the left and had almost different cowl than a R. But if you literally (or physically) cut the front portion of the cab off starting from the door hinges and up to the windscreen bottom I would bet the rear half would be the same for all three.
And if the memory serves well CA47 is a centered R-model cab marking. Wonder which figure marks Superliner cab. It's also centered with zero offset but has different cowl sides to suit the boxed hood.
Edited by Vladislav
https://www.bigmacktrucks.com/topic/68214-mack-r-u-and-dm-cabs/#findComment-480230
Yes it’s pretty much the same cab but like these fellas said from the windshield forwards there’s a lot of alterations for different models and the DM and U model have and indentation on the drivers side for stepping on the fuel tank to get in it … bob
https://www.bigmacktrucks.com/topic/68214-mack-r-u-and-dm-cabs/#findComment-480291
