  • 0
mack r600 to r700 conversion
Question
1 answer to this question
  • 0
The frame rail stampings were the same about the front end shape. The rail heigth was different for R600 standart rail and R700. That wouldn't be of a trouble for the conversion though. Cab mounts were located further to the back and they're probaly a different part than on R600. No doubt the rear cab mount crossmember location and the steering shaft length were different. Also a shift lever in the tranny needs to me modified or swapped. So to me it seems like such conversion is possible with a need of R700 hood and impressive amount of labour.
A bit of addition. The said above concerns trucks made in the US. The brown land R-model engeneering had its own especiality. But in general the matter of the subject is the same.
Answer this question...
