I purchased a r model Mack last year with a twin stick, its an ex plow/sander truck ,now just a cab and chassis (Hell my wife is still mad ). I drove it home and it runs great and shifts fine, steering's a little loose.
seems to be 4 speed with high low reverse
the shift pattern is
1st stick
gear-gear-gear
xxx-gear-xxx
2nd stick
high
low reverse
it pretty cool shifting gears in reverse.
I tried to read other post but they weren't much help.
what is it called 4 speed, 5 speed, 12 speed :wacko:
https://www.bigmacktrucks.com/topic/6864-twin-stick/
1st stick
gear-gear-gear
xxx-gear-xxx
2nd stick
high
low reverse
its a 5spd you use the low if your in some sticky stuff then shift it to high and shift it like a five speed
https://www.bigmacktrucks.com/topic/6864-twin-stick/#findComment-26621
5 speed plus a low hole and add that would be 6 speed ant that what he has?
it is what it is, and what it is is a six speed.
https://www.bigmacktrucks.com/topic/6864-twin-stick/#findComment-26814
Look for 5 postions in the main box. That would be 5 gears and to get a low hole gear put the stick in low or ist gear and then the back box in low. that is 6 gears. The low gear in the back box is to be used in the ist gear in the main box . glenn
https://www.bigmacktrucks.com/topic/6864-twin-stick/#findComment-26821
