2009 trident MP8 starting issues
Crakker
Have a 2009 trident MP8 having issues with it not starting,
When key is turned you can here both the relay and starter solenoid click but won't turn over can take multiple attempts even after ecm shuts power off to starter after trying to long, have checked all earth points cleaned and made sure of good contacts, have check ignition relay and wiring also, had a brand new starter put in prior to purchasing just recently,
Any help would be great
Depending on the brand of starter that was installed My guess is the starter is faulty These starters go thru phazes where you get a bad batch of them !
Tri get the Delco branded stuff when replacing if they off this in Oz!
