- 0
2007 vision cxn613 E7 Fan won't shut off
Question
Shahid
Hi,
Have a problem with when I start the truck in morning, the fan keeps going full speed and truck does not warm up even if I idle for half hour. Once I drive for about 5 km's the fan disengage's. This is an issue because in canadian winter it becomes a Popsicles before it starts to warm up. It is electric BEHR clutch on this. if i disconnected the wire the to the fan clutch still runs same on start up. Is there a way to shut it off manually or does it have a problem I should look at
Thanks for your help.
https://www.bigmacktrucks.com/topic/68817-2007-vision-cxn613-e7-fan-wont-shut-off/Share on other sites
6 answers to this question
