I bought a Granite with an AI engine it has a bad cam does anyone have a good part number for a cam without the extra bump on it. Read on here before to use an AC camshaft. Also could it just put a 02 model CCRS engine in it without a wiring or ECM programming issue?
https://www.bigmacktrucks.com/topic/68868-ai-cam-replacement/
The AI engine and the CCRS engine use the same part number EUP’s so it’s entirely possible. Engine brake type would be a concern I would think .  There is a good bulletin out there that has all the part numbers and info for engine type and engine brake type used
https://www.bigmacktrucks.com/topic/68868-ai-cam-replacement/#findComment-484021
yes sir... one has Jake 690, and the other may be 'Powerleash'..  I'm curios too... If there wasn't an ECM.. this would be a breeze... jojo
Edited by Joey Mack
More content needed
https://www.bigmacktrucks.com/topic/68868-ai-cam-replacement/#findComment-484023
I have a used CCRS engine that already has jakes probably the 690 that JoJo mentioned as it has the spacers between the head and valve cover. Not sure if the newly purchased truck has jake or not not got it home yet to look it over
https://www.bigmacktrucks.com/topic/68868-ai-cam-replacement/#findComment-484024
