I put a gauge at port where fuel temp sensor goes....there’s definitely  no pressure when cranking.
 It pumps up to 55psi with hand pump.I have to wait until I can get someone to help me try to start it while pumping to see if it will start ....
should at least start with 50 psi as log as you crack at least two lines at the head and bleed as described!
i bet you have the fuel pump with the fuel filter on it?    if so.....  Bring a folding chair with you when you go to MackVo... you will need it... Sorry... Jojo
  • Haha 1
$500 range
early E-Techs, But it is possible. In my experience it's the early ones... The one he has IMO was a better pump, just tricky to r+r the filter..  I welcome other opinions...  jojo
