  • 0
1994 Ch613
Question
Having problems with my 1994 CH613 was driving home and the engine shutdown light came on so I pushed the engine override switch down to get to the next exit . When I got there the engine was running fine and so I traveled back to the shop. Next morning I started it to unload and it started fine so I let it build air and pulled it forward to unload equipment and while is was unloading backhoe I noticed black and blue smoke coming from exhaust pipe then it quit! Started one more time for two minutes now it won’t! Changed transfer pump to ejection pump thinking it was not getting fuel still will not start . Anyone have any ideas ??? Don’t want to throw money at something that won’t work THANKS
https://www.bigmacktrucks.com/topic/68966-1994-ch613/
13 answers to this question
  • 0
check the connection at the injection pump plug. the plug should be secured in a yoke.  over time the wires shake a lot and get loose in the plug. when you seperate the plugs, look inside at the pin condition, and gently tug each wire from the back to see if any are loose/moving. if so try to improve the securement of the wire.  do one at a time so you dont mix them up..  I have seen the pins slide back in the plug and dissconnect.. Good luck... jojo
https://www.bigmacktrucks.com/topic/68966-1994-ch613/#findComment-485745
  • 0
Before you buy a code reader, keep in mind that this truck is very simple, and good-old-fashioned diagnostic technic's get it done..  I have a code reader that is made by OTC.. I think I paid $275.00 for it.  I use it often on trucks older than 2016..  I will post a picture of it ... jojo
https://www.bigmacktrucks.com/topic/68966-1994-ch613/#findComment-485747
  • 0
one other thing... look at the flywheel housing at the 8 O'Clock position, (bottom left)  and check the condition of the RPM/TDC sensor.. they get very dirty and oily and the insulation rots away from the wires... jojo
https://www.bigmacktrucks.com/topic/68966-1994-ch613/#findComment-485756
  • 0
Thank you for answering my question and for the input from all . This truck came from Phoenix Az area and had been worked on by some very interesting guys a lot of duck tape and wire and zip ties !! The plug on the back of the injection pump had been duck taped and zip tied together when I pulled it apart water run out of it cleaned it up and put dielectric grease in the plug and it fired up.   Thanks again for the info Clay
https://www.bigmacktrucks.com/topic/68966-1994-ch613/#findComment-486486
  • 0
Well thats good news..  I have fixed that plug a bunch of times... hopefully thats the end of it,, It was my pleasure to help you on this issue. Jojo
https://www.bigmacktrucks.com/topic/68966-1994-ch613/#findComment-486514
Answer this question...
