97 e7 350 valve adjustment
DragoMack
What procedure steps do you use to adjust valves? This past Saturday I did the following
1) take off valve cover.
2)set 1 cylinder to TDC after compression stroke.
3) check valve lash and adjust as needed.
4) rotate 120 degrees to set #5 to TDC and adjust as needed. Repeat in firing order.  1-5-3-6-2-4
5) check lash again on all after adjustment.
