2013 Mack mp8 problem
Hello guys,  I need a little bit of help
I have a 2013 Mack pinnacle with mp8 engine, trucks was running fine I had a dpf deleted 3 weeks ago and now the truck start  shutdown on my while it’s driving RPM get down to idle and gas pedal will not respond turn the keyswitch off and it don’t kill the engine, it remain in idle until the truck is completed parked and speedometer reached “0” and engine shutdown it self
 turn the keep off and on and truck work fine for 15 o 20 minutes and same problem happen again
I disconnected speed sensor when for a run and it just completed shutdown the engine on my since speedometer was on “0” all the time,  reset the keys and y runs fine agains
Only code on Ecm
Mid 140, ppid 278 fmi 9
mid 144 psid 40 fmi 4
One time it show
mid 144 psid 230 fmi 5
A stated by others in your other thread. Its the ECM. The engine has the mechanical ability to run but the computer is not satisfied somewhere along the way and is derating and/or shutting you down. Its that simple. Maybe take it back to whoever deleted it and have them "fix" it.
