I have a 454 Quantum with a jake brake and it also has an exhaust brake, I also have a CH 400 jake brake engine with no exhaust brake, also seen a CH E7 with exhaust brake. Why were the exhaust brakes fitted to some E7 engines, was it noise suppression or did it add to braking efficiency. If it helps braking could I fit exhaust brakes my CH and 2 R model 350 E6s. The 350s both have dynatards.
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/
Well I'm think it was to help braking efficiency on the E7
I dont think Mack ever had the dynatard working like people wanted or expected
I have a exhaust brake from a E7 to fit on my E6 when I get a chance
They are a 5 inch pipe on a E7 and 4 inch on a E6 so I will make a adaptor
Blue Ox Exhaust brakes were the same type of thing
The butterfly type of exhaust brake just went straight on the back of the turbo with no mods
The guillotine type need heavier exhaust valve springs so the valves didn't float when using the exhaust brake
Paul
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489387
Paul
Expand
Just a word on these ! when introduced these were marketed as Stealth brake it only happened for several years I believe! theses played havoc on turbo shaft seals creating real heavy Bloby on application on long steep grades  If you are planning on running this set up and have a lot of long steep grades you may want to think twice on it ! also when these were installed there was a valve spring up date done I don't remember the particulars  on it I only did one of these updates as they dropped the concept after a year or two!
Just sayin!
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489388
Just sayin!
Expand
Correct on the valve spring issue as I had already said, exhaust brakes are probably more common than a Jacob brake across the world, and mainly the butterfly type as they cant over pressurize as they just open a bit and allow pressure to escape
We dont have big long steep declines in Australia like I'm guessing they do in north America, however I have had some interesting moments
So I guess the old saying about pilots rings true"Theres old bold pilots but no bold old pilots" common sense is still critical even with good engine braking
But thanks for your thoughts
Nothing compares to a modern  Jacobs brake that feels like its gunna face plant you on the wind screen, well almost lol
I dont think anything comes close to a modern Jacods brake in a Cummins for engine braking
Paul
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489408
Gotta remember Paul, Cummings have larger cubes than an E7 or E6, so in a sense “there’s no substitute for cubes” ,  we haven’t run the Quantum because it’s still being converted to a tipper so can’t compare yet, The CH E7 jake brake is much stronger than the dynatards on the 350s. Would the 350s brake better if the dynatard was removed and a jake fitted as it looks like exhaust brakes maybe problematic. I wanna be planted in the windscreen haha
Edited by Steve L
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489451
Paul I have a E7 exhaust brake setup ( butterfly type) from a CH if I want it and was thinking of doing exactly the same as you mentioned on my E6 350 4valve. The Quantum was a prime mover and I only drove it bobtail, it’s fitted with both ( jake and exhaust) and it really felt like it was going to face plant in the bitumen, it might be a different story with 40 plus ton sitting behind it, will be interesting to compare when it’s going.
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489453
Steve these questions have been asked on here many times about Jacobs versus Dynatard on a E6 and apparently if there is a difference it isnt enough to notice
Apparently valve adjustment and keeping the gap very tight is the key on a E6 whether fitted with Jacobs or Dynatard
What very tight is I'm not sure, I  feel the butterfly exhaust brake will be fine because if to much pressure is built up it will just push the butterfly  open
Gotta remember plenty of people are running 30 plus pounds of boost on their turbo seals with out any dramas and I doubt the butterfly exhaust brake will ever get that high before pushing it open
Think about it like this, 120 psi pushing a air ram to hold a flap shut and that air ram is say a inch diameter
5 inch butterfly valve is a lot bigger, if we double the diameter of a circle we get four times the area
So it only needs to go to a two inch flap to get enough pressure at 30 psi in the exhaust to overcome the air ram and open it to let pressure out
A guillotine type this will never happen
I honestly think the butterfly type will be fine
And I also think we need to keep our expectations real, it is never gunna face plant you against the wind screen like a Jacobs in a Cummins but I feel good control can be achieved
Paul
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489469
Just sayin!
Expand
Correct me if I’m wrong, but wouldn’t this butterfly style exhaust brake possibly create enough back pressure to open the exhaust valve without a heavier valve spring? I guess that’s why you said there was a spring update….Also with this style is it also possible that it creates a strain on the shaft? Being your essentially creating a “compressor surge” on the turbine side? When the valve closes the exhaust gas flows back fighting against an already very fast spinning shaft in the other direction? End result in time possibly being a broken shaft especially with improper shutdown?
Edited by Onyx610
Spelling
https://www.bigmacktrucks.com/topic/69219-mack-exhaust-brake/#findComment-489476
