I can get them made but delivery might be a bit expensive!
I even have an AC fender as a pattern, but would need to mock up the inner valance that runs from the inner edge of the fender to the top of the frame rail.
Vintage Body, Panel & Wing Fabrication | Boydell & Jacks (featherwing.com)
https://www.bigmacktrucks.com/topic/69233-ac-mack-fenders/#findComment-490023
19 hours ago, Ton said:
i wish you were closer. lol.  thanks for the info.
I wonder how much it would actually be? The last set of fenders they did for me was for a Diamond T 980, and they were big old things, with a back edge and spot welded outer valence. The pair cost £600, which must be about $800. So I wonder what the shipping would be? The AC fenders are much smaller.
https://www.bigmacktrucks.com/topic/69233-ac-mack-fenders/#findComment-490095
3 hours ago, Ton said:
i did talk to melnick metal and they said if they had the blueprints they could make them. i tried to get ahold of the mack museum but they are closed.
You can submit an information request on line at the. Mack Museum website.  That is where they would send you if you called them.  They are still processing requests but it takes a while.
https://www.bigmacktrucks.com/topic/69233-ac-mack-fenders/#findComment-490300
