Radiator issues
Jamesc83
hardware store -buy a length of door screen  fab a custom "bug screen" that would give you access with a small broom . don't think it's possible on the new iron to do like bulldozers /construction equipt  and turn the fan around so it blows air out . more than likely the truck has a plastic fan  besides. larger dozers use to have spring loaded blades. remove one section of iron fan shroud to gain access , push down- rotate each blade. air out for summer = air in for "cab heat". NO you didn't turn the AC on in summer; wasn't any! dozer had same AC as the B model. LOL
