I have to admit...  I've only done about a dozen MP harness's, it's been 4+ years since the last one, until 2 weeks ago..  Take a guess on what I did???  :) JOJO
  • Haha 1
Yes,,, if compression/cumbustion squeezes between the injector seat of the cup, and the bore in the head.  I would expect it to push coolant.  jojo
Another thing,,,,  I dont mean to question youre skill's, but I have to ask...  When you cleaned the cup bores, did you have all of the cups out or just 2? if so, was the cleaning process thorough?  there are galleries in between that can hide particles and bristles from any brushes, and so on. did you make sure the seats were free of carbon and debris before seating the cud. did you use the correct cup installing tool?  sorry about all the Q's, but i have to ask..  was the swaging bit new or within specs?  ok, I will stop here for now..  with respect, Jojo
No issues with questions here, it's how we get better.  As far as the cleaning process, I believe I have the correct tools.  I'm kinda OCD when it comes to prep work, so I'm comfortable that it was clean and ready.  The seating tool I have has only been used once before when I changed the original cups out along with a new injector set.  Purchased the truck and less than 90 days later the bull gear failed...The engine warranty I purchased when I financed the truck had a neat little clause in it that allowed them to get out of paying for the repair.  I call it the "nut clause".  If a part was attached by a torqued nut, and the nut failed, the insurance would not pay...That was an expensive fix.  I said all of that because two months later injector and cup failure began.  It was a tough first year with the truck.
I'm so sorry...  I have only done 3 bull gear replacements, and yes it is a big, EXPENSIVE job.  the last one I did was in a GU rolloff trash truck.  I pulled the engine on that one. I also had to do a harness, rods and mains, and a valve adjustment. So I decided to pull it..  When my servivce manager got back from training and saw the engine on blocks, he flipped out and looked at me and asked what was I thinking, and said we dont need any Mavericks here..  I just finished my work, and when the time came to test drive the truck, I didnt have to go back and re-fix a damn thing..  anyway, a bit off topic, just wanted to share some history..  jojo
  On 2/19/2022 at 1:12 PM, Dan107 said:
I'm going to get a combustion leak detector kit today and check my coolant for exhaust gasses.  Would a bad injector cup let exhaust gas get into the coolant reservoir?
Expand
Yup, like I said earlier the combustion gas can go into the fuel or coolant. Just depends on if it goes on the inside or outside of the cup. Hopefully this doesn’t turn into anything more then a cup for you.
Expand
So, is there any definitive test I can do to determine if it's a cup, or bad cylinder?  First, I really appreciate all the help from everyone here.  You guys have helped me get through issues on many occasions, but this cup thing seems, at least in my mind, crappy!  I guess I'm just being lazy, but the steps needed to pull the cover, pull the rocker assembly, the injector, then the cup and replace without knowing for sure seems labor intensive.  Don't get me wrong, I'm not questioning anyone here.  I'm just trying to get to the answer the simplest way possible...😎
Hahaha yea I get it man, I completely feel for you. It’s a shame these are such a pain to tear down. There isn’t really any pin point tests that I know of. It’s pretty much just a known issue and the symptoms that come with either combustion gas in the fuel side or coolant side. Even then the main test is the clear hose either in the fuel return or clear hose from head to surge tank to check for bubbles. Also another one is what your getting ready to do, combustion gas detector. Only problem is that it could be other things if combustion gas is found. Like egr cooler, head gasket, or cracked head. Which I highly doubt.
Okay, I got the combustion gas test done and it was positive.  Also, for whatever reason, now I have oil literally running a steady stream out of the crank case vent tube from the ventilation cannister.  I think I'm just going to set this thing on fire!!!
Edited by Dan107
Lol sounds miserable!  Clean your crankcase vent filter. I'm assuming the mp series engines use one. The ETechs use a steel wool donut that clogs up over time.  If your vent is plugged up it'll pressurize the crankcase.  Even a tiny bit of pressure will cause things to leak.
Ok so time to go back to the offending cylinder…now for the blow by, those crankcase vent spinners are very expensive so I’m not gonna tell you to just throw one at it. There have been issues with them though. May want to check for pinched hoses.
Edited by Onyx610
You can’t clean the filter on these. These are a centrifugal style filter and I believe you have to buy the whole housing. How many miles are on this truck? It could be very loaded up and blowing out past the o rings.
Edited by Onyx610
Expand
it's amazing how there are those that put time vs quality on a job. do it right the first time makes more sense ; then there won't be a second time for the same situation.
Expand
You are correct sir, I got a quote today for $1500 drive out, with the gasket needed between the canister and the block....So, I did clean it up and put a "rebuild" kit in it.  It was nothing but a set of new gaskets.   The internals seem clean, and free of damage.  The wheel spinner turns freely.  It was running oil out at 1100RPM's and stopped when I went back to idle.  I had spoken with another diesel engine tech and was told to do another injector cut-out test to see if the blowby decreased when cylinder 1 was turned off.
Expand
952000 miles on this truck, and I've had it since 533000.  There are a few video's of the internals being cleaned, and as I mentioned, a "kit" is sold to replace the o rings inside.  I pulled the valve cover off, and it looks like I have very fine particles of metal up top.  Granted, they are like a fine powder, but looks and feels like metal to me.
I've pulled the cup from #1 cylinder, and as soon as my snake camera is charged, I'm going to take a look down in the cylinder to see if I can find any damage.  Luckily, when the gov was giving PPP loans, I purchased a complete in-frame kit for it in case this were to happen.  It's been sitting in my shop.  We'll see what it looks like inside and go from there.
  On 2/19/2022 at 10:29 PM, Onyx610 said:
Yea cleaning them doesn’t do much of anything, the cut out test on the cylinder is a good idea. Did the cup in the cylinder show any soot/pitting on the outside?
Expand
I saw nothing on the outside of the cup.  Still shines.  The injector was really sooted up at the nozzle though and I cleaned them up when I changed the cups before. Don’t know if that means anything.
Are you able to do a compression test or leak down test? Not using tech tool? That sooted up nozzle Is pry from it not firing correctly hence being your “injector 1 error code” or compression loss. If you still can take a magnet to the oil to verify if it’s metal.
Edited by Onyx610
No, because you have combustion gas in the coolant system. Id Iike to see the cup re installed and a legit compression/leak down test done. I think you have a few things going on but we need to start figuring out one thing to get to the next. One thing might tell us the rest of the story.
I strongly believe we can figure this out, do you have the tools to do those tests? They cost a good bit of money….I hope some of the “big dogs” as I like to call them that i mentioned earlier will chime In soon.
