15 hours ago, 1961H67 said:
It got warm enough today that I put a coat of primer on my inside door panels, hoping to paint them soon and install the windows . Making progress on the bridge to the shop, cement poured, hopefully we can set beams next week. It will be SO NICE to get back in our shop!
Is it for your personal shop, or a business? Glad to see progress being made.
I installed my left window glass in the LJ Friday, nice weather for February. Then early Saturday morning 7 volunteers from an organization called Hope Mill showed up and helped My Son and Me set the beams and flooring for our bridge to our shop! A LOT of work in one day! Great group of volunteers! I have some pictures but for some reasons it keeps showing files are too big???
  • Thanks 1
On 1/30/2025 at 9:04 PM, 1961H67 said:
Took the forms down today, we are going to let it cure for a week or so, before we start setting the beams. I bought a complete bridge and hauled it in ( it was a NC state road bridge) . The shop is for our business, we occasionally work on customers trucks, but mostly ours that we haul equipment with.and usually there’s an antique project in the corner. Thanks for the compliments , I’ve learned a lot from some of the guys on this site and have personally seen some of their work that’s amazing!
Very nice..just curious-how far below grade are piers.? Rebar?
  • Solution
The bottom of the footing is about 4 feet below water level, with rebar tied up to the abutments, we channeled the water down as deep as we could and used pumps to keep the water from seeping in .
  • 4 weeks later...
Excellent, great progress and you're closing up on having it done.
If you can't post pictures from you're computer, try making a post then editing it from your phone and adding them from there. I've had to do that numerous times to post pictures. I don't know if it's a formatting issue or something. Also, I've waited a few days after taking pictures to post them then dropping them in and they go, no file size issues then. No idea why that happens , I didn't reduce the file size.
10 hours ago, 1961H67 said:
I finally got some NOS headlights, I took them apart to paint them, it was like looking in a Time Machine, cloth wiring, perfect! I have the door panels on and the window glass in and working, hopefully I can get it ready to make the show at the NC Transportation Museum on May 10th . ( I can’t post any pictures, it tells me the file exceeds 26.44 kb , I’ve tried to reduce the size but it still says it’s too big? Any suggestions? )
Great to hear the progress your makeing with the truck and the bridge after the horror story you have been through.Upwards and onwards is the only way to go.Good luck.....
Paul
