you are over joe...if the measure is correct.... I would like to hear from MackPro on this as well. I learned .1000 is the max..  however...  i have never  pushed that issue... the most i have ever shimmed was .012"..  the shelf is 4.010" ish - 4.030" ... stock....liner protrusion allowance is .023" - .029"   with .002"  variance on the front 3 holes and the rear 3 holes... however, I always want to learn from others on this.. .  jojo
Edited by Joey Mack
Poor spelling
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490544
I was think the book says no more than .030” in shims but I remember cutting the counterbore way more. I wish Mack or aftermarket would make some thicker shims than .010” or at least that was the thickest we ever got to use back  then. I know the Reman center cuts the counterbore 3/4” and drives a stainless ring into the block to get the counterbore to the 4.00” to top of block measurement.
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490562
What was old is new again! This was done back in the day of the V8 and N14 I had no idea they did this with the E7 Thanx for posting that pro!
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490636
One of my engines was getting coolant in the oil so i found it was passing by #2 liner to block stop and i pull it to find its crack some.Mack sent a hand out to cut it and he had to go to .060 deep to clean it up.He told me i needed a block but he had done this before and no problem.I shimed it and i think i have about 150000 miles on it and it has not dropped as for as i know.Yes my manual say .030 max also but i said me running it i will know if it starts to leak compression so i will take a chance.
  • Sad 1
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490640
We rarely ever cut counterbore on the E-7 or the ETECHs till after they made the coolant filter/conditioner optional in around 2002. Of course fleets and cheapskates ordered trucks without the coolant filter stand to save $50-$75 per truck . 8 to 10 years later coolant in the oil and damaged engine blocks with pitted counterbore ledges everywhere. 2002 was also the year we started seeing the casting core sand not flushed out of the engine blocks during assembly. This clogged the air compressor coolant line causing the air compressor to overheat , blow the air compressor head gasket and pump/force coolant up the air intake pipe and dump coolant into the back of the intake manifold where #6 piston then sucked in the coolant and hydro locking the engine, bending #6 connecting rod. Sometimes so bad we had to cut the rod with a torch to get it out . And this wasn’t rare , one time we had 2 trucks do it on the same day . However, 2002 was my favorite year , a axle forward CH with a CCRS 427 and a Fuller Super 10 trans was my dream truck and still is.
  • Sad 1
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490643
I remember those days in early 2000..  I did quite a few core sand repairs and stand pipe updates..   as far as cutting counter bores, I remember measuring the shelf in 3-4 spots, and looking for cavitation that went from the bore wall out to the edge of the shelf..  thats when we cut 'em... jojo
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490649
Does that core sand happen to be like very fine and black/dark grey? Had some coolant drained out in a 5 gallon bucket on one of these and saw a lot of that. I figured it was casting sand. Never knew that was a legit issue with them.
https://www.bigmacktrucks.com/topic/69299-etech-liner-shims/#findComment-490652
