I have a customer that has a '96 RD. He wants me to pull the elec. inj. pump, and install a mechanical inj. pump.. I assume both are robert bosch based on the year. But I havent gotten all the details yet..  I have never done such a swap... would I just use the pump degree settings from the mechanicle pump, and install it that way..  I have only ever re-installed the pump's that were on the engine originally.. I have the tool's, most of the knowledge and all the Mack books..  I welcome any help...   Joey Mack...
Maybe Glenn will help me..  Heck Vlad may know as well... so many smart people here..  Paul may know,,  "V" and "F"  ??  too many to remember....   jojo
Thank's Glenn.. I was hoping you would respond..  my cust. has 2 engines, im pulling the pump off one and putting it on the other. so I should be able to see the plug you mention, and as far as the lines, I hope to use the lines he has,  i expect that I will have to buff the ends so they seal.. I figured I would use the timing for the pump that I am keeping..  thanks again.. jojo
On the injector lines make sure and blow them out before you install.I have many lines laying in the shed and i think ever one of them may be stopped up.The last pump and lines i took off and stored i wrap tape around the ends.There is some kind of small bee like animal that gets in there and builds a nest inside of the lines.
