Got a 2010 Mack Pinnacle dump truck and all the lights come on R&L Turn, Head Lights, Cabs, Side Markers & Brake Lights work fine and all light up however, the blinkers do not blink. I have no fuse box diagram for this truck can anyone help please.
Check/replace the flasher . It’s in the fuse box on top of the dash . It’s to the left of alll the small fuses , its square and tall and has only 2 prongs.  It could possibly be melted and stuck to the fuse box , this was a common problem and there was even a recall about it . Use only a Mack flasher as it has longer prongs to reach through the thick fuse panel housing . Aftermarket flashers have shorter prongs and barley reach the wires  to make contact. This caused a poor connection and it would over heat and melt the flasher to the fuse box housing .
